A beautiful day... Springs here...
Highflyer
Sanborn, Mn (USA)
beautiful scenery
Reactions: Surfnut
McCloudSpark
Nice peaceful and beautiful video! I love the rock colors and contrasts.
Reactions: Surfnut
Surfnut
I wonder if you guys can offer some advice though? In one of the vids I watched a guy suggested slowing down the Gimball setting to 18 for smoother movement, but it’s just made mine unusable. I have to turn the wheel half a dozen times, and the footage is stiff and jerky, not exactly what I was going for? 😂 Has anyone found this? Is it just trial and mostly error?
Spark 317
Indiana, USA
Go slower on the settings.
The gimbal wheel is also touch sensitive.
A light turn of the wheel results in slower tilting of the camera and with a lower setting could produce smooth shots.
Assign one of the buttons on the remote to quickly tilt the camera up / down if the gimbal speed is too slow for the wheel when you want to reset the camera view.
You can always change the speed later.
Good luck. 🙂
Reactions: Surfnut
graywoulf
Endeavor to Persevere
Millers Creek, NC
Very nice scenery. It must be nice living in that big white house on the hill and enjoying that view every day. And by the way, God is spelled with a capital G just so you will know. Its a respect thing. ;)
Reactions: Surfnut
Surfnut
Than
Good luck. 🙂
Thanks Spark. I’m literally finding that with it set on 18, it’s taking about 5 or 6 turns to get it up or down, whether I apply hard or soft pressure. I am planning to do what you suggest on the rear function button. I ll try it again. I just wandered if anyone else had experienced that?
Reactions: McCloudSpark
McCloudSpark
Than
From your post it sounds like you think that you are turning the rotate knob like a screw. I wanted to make sure that you understand the the knob just rotates about 1/4 turn in each direction with a spring return to center. You rotate it left and hold it and the camera will slowly rotate down (and rotate right is up). The farther you turn it the faster the camera moves. Sorry if this is already understood...
Surfnut
Thanks McCloud. I don’t think I was understanding that properly. Maybe I was just being impatient. I’ve increased it to 36 now, and I ll give that a try. Thanks again...
lmel2005
If you are referring to gimbal pitch speed, I usually have it at 10, and it's smooth enough.
It's not need to turn the wheel and release it repeatedly.
If you hold it turned, gimbal moves all the way up or down.
freesparking
