About Spark Obstacle Avoidance
EdisonC
My spark is functioning normal but the only i noticed is the front obstacle avoidance is not working...
But i can see glowing red light
But i don't see error alarm.
I tried restoring to default settings and refresh the FW, but it did not fix it
Is it turned on in the app?
The infrared beams are still being emitted and should still tell you when you are close to something, the Spark just won't stop you from flying closer when it is turned off.
Try selecting one of the gesture options, such as follow me, and see if the OA works.
I usually fly with mine off, but if I use one the gesture commands, the Go4 app asks me to turn on the OA.
If it doesn't work or you can't turn it on, there may be problem with it.
But if you don't fly close to stuff, it may not be a problem at all.
I'm curious it it's faster now that the obstacle avoidance is not working. The Spark is much faster with O.A. turned off.
csdisme
