Battery fault
Kevkev
Bought a used spark It says it's had 36 flights I wouldn't consider it to have much use but my flight time is only about 4 min max After it gets to 3 min flight time It gives me a battery warning and starts to land where ever it is l have to manually bring it back to me while it continually tries to land
Wondering if anyone else has had this problem
If the battery has had the absolute maximum level of abuse it could easily be stuffed in 30 flights. In the GO4 app you can see the cycle count and voltage levels for the battery which may help with further diagnosis.
