Beyond 400 ft
Big Ben
In an emergency situation and I had to get my Spark OVER 400 ft. how can that be done? Now mine is maxed out at the 400 ft level. I would never go over 400 ft buy if I had to.....
What kind of emergency did you have in mind?
LOL well you never know but I would like to be able to. My Hobson had no issue going over 400 plus
The manual says max altitude is 500 meters and can be set in GO4.
Not sure how true it is but I've heard and have not done any research what so ever on this subject but I think you can fly over 400ft as long as you are with in 400ft of a structure. So say a building is 100ft you could go 400ft above the building.
I set my Max height at 200meters (656.167979 feet).
Very seldom go over 400' but I have been shooting a 28 story building which is about 320' tall.
That is the only place I exceed 400' above home point.
True, that's an FAA Part 107 rule for the USA only though.
In mountain area, the 500 meters could be a limitation even if you respect the maximum altitude over ground, but the 500 meters is fixed by DJI.
ChunGreenh
