camera coverage
djmatt
Camera coverage: How do I determine the area covered by each photo in a manual shot? i.e. based upon distance from the object?
Hmmm....not sure what you're asking. It should be what you see in your screen as it's the same camera.
The published Field of View for the Spark is 82 degrees.
The necessary maths is 2*Tan(82/2) which says that the width of the field of view is 1.7 times the distance from the object.
HTH
Nik
Here you'll find the Sparks correct values (from exif data)
  • Pix4D_GSD_Calculator.pdf
csdisme
