can someone point me in the right direction for DJI+Assistant+2+1.1.2
Gavieboydgi
ive being looking everywhere for the Download but cant find where to download it from a safe website that has it.
Thanks Gavin U.K
Pmsshop, I’ve got the Dji assistant 2 ver 1.1.2 loaded, all works well, however when I get into parameters and try to change a value, it changes and as soon as I clip off the number it goes right back to what it was. Is there some way to save that change or am I doing something wrong? Any help would be appreciated. Wink
You have it to where it looks exactly like the video?
Depends on what you want to change.
Not everything can be modified.
About the only thing I change are the YAW rate and expo
Changing to ATTI Mode use to be a feature on the Phantom.
You should be able to reassign switches but I'm not sure how.
One thing comes to mind, you have the transmitter on, right?
I think the switch change has to reprogram the transmitter.
At least that is what I have to do when I change the YAW rate or expo since those values are in the controller.
jobaeit
