Can Spark Settings be set to new defaults
Palmcomp
I'm a new Spark pilot. Wondering if various flight and camera settings can be set as default. Seems I have to re-set for each flight.
You mean like, "Histogram On"?
Most settings it remembers. It used to not remember that you had the histogram on, and you had to go and turn it on each time. Now, it remembers that you had the switch on, but does not display it until you go in, turn it off, then on.
Reactions: I B Spectre
Ok thanks ... I did a bit more experimenting today and you’re right it does seem to remember most settings. The histogram is a bit different. I’m assuming changing batteries won’t change the settings. We’ll see on next flight. I’ve been using a OTG cable and so far all is good.
EmirOmerov
