- Join
- Mar 5, 2019
- Messages
- 3
- Age
- 28
When i press 'Cache to Sd card' on the settings, i can't see my drone Sd card in the phone settings, any help?
But is it possible to not cache photos/videos on the phone? I haven't found that setting on the app for the Spark.Some people (like myself) find the app crashes less on Android if you don't cache photos/videos to your phone.
Just as I thought. So there is no straightforward toggle switch in the app which enables/disables the cache recording.Apparently it varies by Android/iOS and app version. One person says the solution is to go into the app without the Spark connected: Uncovering the video cache switch in DJI Go 4.2.x Android App May need to do some cache clearing too.
There is definitely an option to set the cache size in Android as well but I am not sure if it can be set to zero. Need to check this.If using iOS you can set the size of cache to ZERO.
Yes. This is exactly why I have it ON now.But it would be good to have some small cache for visible landmarks just in case your drone went missing
Btw, I have noticed that my cache video doesn't seem to play in normal speed. It seems like 2x or 4x speed always.
Is this how it is meant to be or am I doing something wrong here?
Sorry if I have failed to explain properly, but I was talking about the cache recording on the phone.Make sure you are using a fast enough SD card.
