Compass error after storage in a cold car.
Noran_85
Norway
Hey. Accidentally forgot the drone in the trunk of the car. He lay there for 2 days (the temperature outside was -5 degrees). Today I launched a drone - immediately after takeoff, a compass error appears and the drone goes into atti mode. What happened? How to fix it?
Northwood Mediaworks
Transport Canada Certified
Northern Ontario, Canada
northwoodmediaworks.com
I would recommend you do a calbration well away from any structures, electronics, any metallic objects (even your belt buckle and watch). Even better if you have someone with you, you can get them to run the calibration command at a distance and then you follow their directions on moving according to the app.... I do this with the wife once in a while. She likes to tell me what to do anyway, so it works out fine! :rolleyes::p
Noran_85
Norway
Cool when the wife understands your hobby. Tomorrow afternoon I will try to do this with my wife.
Noran_85
Norway
I did it. It didn't help. Problem still exists. What else can I do to solve my problem?
Grin factpr
How many satellites do you have before taking off?
My spark has gone into atti mode before when I took off before acquiring satellites.
nilanjan118
Japan
Once you power on the AC, let is sit on a level surface or landing pad till the top of the Go4 app shows "Ready to Go (GPS)". I think this appears once the AC has acquired 9~10 satellites and usually takes about 1 or 2 mins. So be patient and do not take off if "No Positioning (Atti)" is displayed.
Noran_85
Norway
I always wait for takeoff resolution (10-12 satellites) The problem is not my impatience.
surfingvideo
