maybe I will not shine intelligence. , but sometimes the best way is to restore the initial settings. This is one option. drugs, as a colleague wrote, it should be re-calibration of all sensors. You can also choose in DJI asistans2 options for uploading software for Spark. start from two versions back. after each data entry, Spark will probably want to make the latest update. if so, after all this, calibrate From scratch. I think this will be the result. Be sure to avoid interference during calibration that may interfere with correct calibration. I have shown a compass error three times. I calibrated it anew away from the buildings. and it works great. let me know what you did. Take care. successful flights.Hi guys. The copter was kept in the closet for 1.5 years. Today I wanted to use my drone. Could not use drone. As soon as the drone takes off, a compass error immediately appears. Nothing helps to remove the error. What should I do?
You need a new battery.
I'll bet if you look a your logs in AirData under power then cell graphs you'll see that just about every compass error has a downward voltage spike in one or more cells, at the same time.
Just an observation of mine made after my friends Spark spent the night in the tree. His would only throw errors with that one battery.
Good Luck
How often should you plug spark into a computer and look for updates?
Thanks for the advice, friend. I calibrated the compass, it did not help. I think to buy this device - cfixerHello from the Hoosier Heartland, Aksa_1989.
I have read a few threads in the past concerning this problem.
From what I have read, this item fixed the problem.
CFixer
Try the compass calibration first to see if that corrects the problem before purchasing something.
Welcome to the Forum. ?
Cool advice. Tomorrow I'll do it and let you know about the result.maybe I will not shine intelligence. , but sometimes the best way is to restore the initial settings. This is one option. drugs, as a colleague wrote, it should be re-calibration of all sensors. You can also choose in DJI asistans2 options for uploading software for Spark. start from two versions back. after each data entry, Spark will probably want to make the latest update. if so, after all this, calibrate From scratch. I think this will be the result. Be sure to avoid interference during calibration that may interfere with correct calibration. I have shown a compass error three times. I calibrated it anew away from the buildings. and it works great. let me know what you did. Take care. successful flights.
I changed 3 batteries. The error remained. It did not help = (You need a new battery.
Good Luck
Never connectHow often should you plug spark into a computer and look for updates?
My compass was magnetized(so said in the service center). I used a special device - cfixer and the problem disappeared. thankAnd? You have info?
What is the price? I could not see that ....Glad to hear you are up and flying again.
I thought about purchasing a Cfixer just in case I may need it in the future.
