Damaged fan after crash?
spel
Hello,
My Spark is unfortunately pitched on the floor at a quick fall (sport mod).
Then turned 180 ° and then lay on his back.
- The propellers continued to turn
- I could turn it off then
- The fan was not heard then
- there were some mistakes:
Data error: barometer
Error: Encoder (0x1000000
Error with the navigation system
After a restart, everything actually worked again:
- GPS: OK
- Compass: OK
- IMU: OK
- Gimbal: OK
- Video: OK
IMU calibration was ok
Only the fan did not work. I have ordered a new one. The fan just twitches a bit, but never really starts.
There was another ad after that:
Error main controller
If I turn off the Spark, the last (4) LED flashes 4x.
At a start an IMU calibration was necessary.
Now I am a bit worried about the Main Board being affected.
Can anyone give an assessment here? Also regarding the fan?
Can you see more with the DJI Assistant?
Many Thanks!
First welcome to the Forum :)
I'm sorry that I can't help you with the fan problem but it seems like there is another problem. The spark normally stops the probs when a flip is detected. Can you try to start the spark while holding it and when the probs run turn it. When the spark don't turn of the probs there is maybe a problem with the IMU or Conpass
Reactions: Andre Levite
Hello,
- GPS: OK
- Compass: OK
- IMU: OK
- Gimbal: OK
- Video: OK
Many Thanks!
Send it in...
Detlef
