Find your best video link on the ground.
Make it part of your pre-flight checklist.
Operate in manual frequency selection.
1) Switch to manual
2) Switch to 5.8ghz band
3) Watch the spectrum for a while on the higher channels
4) Look for the channel that does not show red for any long amounts of time or does show some green
5) Select that channel and fly.
2.4Ghz has longer range but will not cut through vegetation as well as 5.8Ghz can.
Sparks cannot perform "real time manual channel switching" like higher models (not sure where it starts).
But with those higher models, you can switch to a better channel in flight.
And the higher models can select Mbps transmission feed - use 2Mbps for less latency or if you see "freezing/ pixelated.
1) Switch to manual
