DJI Spark mod baterry
taras
Joined
Jan 27, 2018
Likes
#1
I fly to such a battery, the last time does not see the altitude, soars and shows that the height is 0.3 - 0.8 meters, although in reality the height is 20 meters. he just flies up and does not see the height. today threw this error:
downward infrared sensor failure
land as soon as possible
on stately batteries, the norm is working, which can be
Likes: un1tb4ck
Spark 317
Joined
Jul 10, 2017
Likes
724
Location
Indiana, USA
#2
WTF?
Looks like a Frakenbattery.
It's ALIVE...sort of.;)
Sorry I can't help you but I don't see that configuration in the manual.
taras
Joined
Jan 27, 2018
Likes
#3
this is the three batteries of 18650 connected in succession during the flight of 22 minutes, interconnecting a crossover balancing rope which is soldered in the battery of the battery, had previously flown and had no problems and now does not see the height
Cleo55
Joined
Feb 11, 2018
Likes
3
Location
TN
#5
What is the max weight will the Spark support when it comes to adding "spot lights" to it? I know the ones I looked at use a single AAA battery, and there's two of them.
taras
Joined
Jan 27, 2018
Likes
#8
This battery weighs 170 grams, sparrow flies perfectly with it, the motors do not heat up and the controllability remains the same.
Kelvin Tee
Joined
Jan 30, 2018
Likes
2
#9
I have been thinking of this mod but do not know how to connect the external battery to the 4 electric pad on the battery. Can you share this info?
Is 18650 discharge rate too low to sustain as a external battery?
Thanks
S2-D1
Joined
Feb 13, 2018
Likes
#13
Olá, fiz uma soldadura na placa da bateria do dji spark ela mostra uma carga mas não aciona a bateria. O que pode ser?
Google translation of above post:
Hello, I did a welding on the battery plate of the dji spark it shows a charge but does not start the battery. What can it be?
So I’m very interested in these battery mods and have been watching the forums for info, so I am informed when I actually perform my own mods. Great stuff here.
As for your problem mentioned above. It must have something to do with how the original battery connects to the spark frame with 6 pins. 2 positive, 2 negative, and 2 for data making it the “Smart Battery”.
Your mod only uses the positive and negative when connecting to the aircraft frame from what I can see (not enough info in your pics). But your still trying to use the smart part of the old battery without reconnecting those data connections. Leading to the problem of not being able to “start” the battery.
Hope that helps
Guilherme
Joined
Sep 4, 2018
Likes
#14
Mas acabei removendo as células originais e soldar um conector de simulador de uma bateria original. Eu não sei porque o cartão não liga.
Babydave
