DJI SPARK UNBOXING & HIDDEN FEATURE FOUND (Increases range)!
Jared Reabow
DJI SPARK UNBOXING & HIDDEN FEATURE FOUND!
Watch this video for the fly more combo unboxing:
Watch this video for for the hidden feature of the DJI Spark:
How to connect via a cable:
DJI spark usually connects via wifi to your phone , either through the controller or directly, but there is a BETTER way which increases range because you don't interfere with the drone connection by having wifi switched on.
Reactions: WPS and Kiteboy
I already attempted this on an IOS and was not successful. I will play around a bit more with it.
Hope it works as I just ordered a microUSB to lightning cable from Amazon.
I ordered the Micord @ $8.99. I thought they had a 90 degree to 90 degree, but that was a USB-C to Lightning cable.
Can you guys confirm when you use the cable to the RC method you are not getting a wifi strength signal on go app to the spark?
@Jeplane, I thought that's was it, but that is a USB-C instead of microUSB, so I ordered the Startec 8" one above but from the USA Amazon site. I can use it to transfer files directly from Spark to iPad Mini even if it doesnt work as a direct link from RC to iPad Mini.
vdbnoe
