Doro Case Any Good? They Have A Double Decker For Spark And Acc
Pappy
Anybody know if Doro cases are as good as other hard cases, such as Pelican or GPC? I just spotted this double decker case for the Spark at B&H Photo (DORO Cases Hard Case with Custom Foam for DJI D0907-6-SPARK B&H) and it's only $42.95. It's like other hard cases with an o-ring seal, vent valve, and two latches. What makes this one unique is it has two foam trays. The bottom one holds the Fly More charger/cables, two batteries and propeller guards. The top tray holds the Spark two batteries, RC, charging hub, spare propellers under the Spark, and memory cards. Seems like this hard case gives you the most bang for your bucks, holds everything from the Fly More package and then some.
Looks decent.
My only concern would be the quality of the foam inserts. Looks a bit cheesy....
But, I'm a faithful GPC case user.
Don't these HUGE cases totally defeat the purpose of the Spark ? ;-)
Here's what I've done :
1. When I'm out and about :
- PolarPro for the Spark+2 batteries
- RC Case (also have stick protectors but they don't protect from dust/bang)
2. When I travel :
- Same as above + case that came with the combo for all the cables and accessories
