- Join
- Jun 14, 2022
- Messages
- 20
- Age
- 42
Hello.
I'm searching for F1C50 power supply pinout.
I would use another power supply on my Chargin Hub.
Any idea?
Ok, I should have tried first.
It's same battery pinout
Using 2 pin I can power up the Charging hub.
Charging hub start working from 8V but use always same input current from 8 to 13V: 2A.
This mean that greater voltage greater power (W=V*I).
At 8V = 16W
At 13V = 26W
(Excluding current consumed by charger)
I don't know what's the max voltage of Charging hub and I'll not risk over 13V.
I'll use a 5S drill battery (4Ah-5 cells) connected to a DC-DC converter to feed the Charging hub.
Then, I'll be able to charging like a portable station.
Any idea?
At 8V = 16W
At 13V = 26W
