The Spark has a fixed-focus lens, you can't adjust it. The problem with the night shots is more likely that the shutter speed is probably quite low so the images are blurred
They look pretty good for a 14 mp lens.
Right under, closer, everything look fine but
at distance, it look haze or a little fog.
And 1second shutter speed, good shots.
The stabilizing system is amazing in the Spark
It’s most likely motion blur. The name of the game is to get the spark as still as possible. You need as little wind as possible. Pause before each pic to make sure drone/gimbal has finished moving. Tripod mode not much help for stills at night. I often underexpose for night pics and bring the shadows up in post.
