Gimbal controle on screen.
Defjoe
Hi. Instructions video’s talk about different ways to control the gimbal. Amongst them rotating the iPhone. I can’t find this possibility. I can only rotate the gimbal with a double tap and then slide up or down.
Missing something?
Which step in the above video are you having trouble following? All seems to worked as described.
First one. Don’t have the symbol upper right corner to activate or deactivate tilt
Seconde one. Can’t push the up or down button. Buttons are not there.
Number three works.
Is your mobile device connected to your Spark's Wi-Fi? If not, you'll need to setup that connection before those options will be available in DJI GO.
FYI, those extra gimbal features are not available in DJI GO when using the Spark remote controller.
