Gimbal stuck
Festijn
Hello,
A couple of weeks ago I did a firmware update via the app. I let the update do and when I checked after 5 minutes I saw the update was done but also the gimbal overload warning. At the same time I saw I was forgotten to remove the gimbal protect hood. My ‘costly’ mistake. :eek:?
With my next flight I had no problems during startup. Everything went fine. I could move the gimbal up an down.
But after a minute it seems to get stuck and the image is shaking.
I’ve got this now with every flight. It could be after 30sec, after 3 min,...
The strange thing is that as soon as I land an take up again (without intervening) the gimbal works again.
It is so strange because at first point there’s seems nothing wrong with the gimbal. When I test it on a table I can move it up and down quite a lot until some time it doesn’t react.
Is there someting I could do to solve this problem? In the mean time i’ve tried to downgrade firmware and reset to factory settings without result.
I hope there is still a solution.
Thanks for your help.
Grt
Festijn
Reactions: Andre Levite
Hello,
Grt
Festijn
Try an IMU calibration. Try uninstalling and reinstalling the DJI Go app. These are long shots that have worked for others and only take a few minutes. It's cleared up some weird camera problems for me as well.
If you have a filter on the camera -- remove it. Remove sun hood as well. (kind of obvious -sorry).
Use DJI Assistant 2 program to reset gimbal and downgrade firmware (I have no firsthand experience with that one). Can tell if that's what you described you did.
If ask those fail I hope somebody has better solution. Gimbal repair by DJI quoted was $76. ThunderDrones has a good reputation too - he's active on MavicPilots Forum.
Thank you!
IMU calibration and downgrade I have already tried withoud succes.
I will try your other options. Removing uv filter and uninstalling the app.
Didn’t knew reset gimbal was possible via dji assistant. I’ll search for it.
