Go4 editing tool
Icemanwbs
When using the edit tool in the Go4 app, how do you get to use the video clips with the higher resolution ( from sd card onboard spark).
Open the editor. Click on album. Look at upper left of screen. You will see a box with an arrow running diagonally through it. Open that. You will see locations to import media from. If you copied the media to your device, select local media.
Reactions: Icemanwbs
This is going to be a ridiculous solution, given the cost to implement, however, if you get a DJI crystal sky, you can take the sd from spark directly into the CS.
I mention this simply because the CS monitor is a brilliant monitor, and really pumps the video
Isn't a separate holder required? Or does it fit under the RC ?
A holder is necessary to use the CS as a monitor while flying though I imagine you could prop it up on a table separate from the RC, but I was referring to using the CS to view the photos and videos after the flight
Oh, ok. Odd though that it won't fit in the RC , as tablets up to 7 inches will. But I do get what your saying. Thanks.
Ok, thanks. I'm hoping to get a good deal on an Apple iPad mini thru Ebay.
jobaeit
