Hardware replacement, still showing errors
pbaverey
Hi all,
I had a bit of a crash with my Spark and had to replace the gimbal and camera unit.
After I replaced the unit, the error did not clear off the DJI App on my phone.
Does anyone know if you need to do some kind of software / sensor reset after your replace a broken component?
Thanks in advance.
Thanks for the response, I’ll give that a try. - you never know.
Initially I’m thinking more about how do you reset all the sensors and errors on the actual drone itself.
I’ve tried a factory reset via the DJI Assistant app and that didn’t work.
I think you have a hardware problem that is not reset-able.
If you reinstall the DJI Go app and reset the aircraft with DJI Assistant but still get error message for camera and/or gimbal then the simple hardware swap didn't fix all that was broken. Professional repair would be best option. Consider a DJI Care Refresh policy once everything is again working properly.
It looks like it’s going to have to be a Pro Repair job [emoji53]
To reset the aircraft in DJI Assistant, is this the same as refreshing or updating the firmware? I don't see an explicit "reset", but anticipate this would do the trick.
vdbnoe
