Height indicator on the iPad screen through DJI 4 go reads erratically
Twesty
Height indicator reads the height and jumps to a lesser height with an arrow pointing to the right (black and white) with 2 lines (like smiles) below it. It will then jump back to normal height and the lines and the arrow disappears.
Are you flying less than or around 25 feet?
Although the Spark may have the Home Point GPS lock, under a certain height the Spark uses the bottom camera as it probably hasn't risen high enough for full control ( barometer, gps count, etc), and at a certain spot in height, the display may flash back and forth.
Thank you for the reply. The height will continue to fluctuate up and down continuously even when up at 250 or 300 feet. Seems to indicate and stay more at the higher height though.
Pilot6521
