Help! Initial IMU Calibration gets stuck on step 2/6.
Try following these instructions:
Reactions: MVGsparked
Help! Initial IMU Calibration gets stuck on step 2/6. I've redownloaded the DJIGO4 app, but still no luck!
Pay attention to the DJI logo on the screen shot when calibrating.
You're not the first pilot to get stuck on step two.
Reactions: Romano
I did the same thing, #2 looks like its turned flat on all 4s that way ,but its up on its two arms facing you.
At least that was my problem,,lol.
This is a great forum!
Solved my error 13... Had to have a cold drone, cold battery, and cold temperature outside before it would work. But, it worked finally.
My IMU will not calibrate. error code 50, Its not the same... can anyone help me
I did a quick search on Google and scanned through a few threads.
Some were saying to send it to DJI, others had suggested using the DJI assistant 2 under"advanced" settings?
vdbnoe
