Loss of signal to controller
CenlaUAS
Bought a Spark to play around with. Have a Mavic Pro also. Certified 107 for almost two years. Pre-flight check done.
Flew the Spark for second time and the following happened:
While hovering about 30ft high at a distance of about 75 ft from me, a text message came through on my phone. At about the same time, I lost video feed and had no control over the Spark. RTH initiated and the Spark returned to take off area. As it was descending, I was able to use the contoller to move the Spark sideways but still no video. Moving the Spark sideways indicates I had regained some control with the controller. The flight log on the controller does not show landing.
Could the text message have caused the wifi to disconnect from the controller?
Thanks for the help.
Reactions: alex_hidrobo
alex_hidrobo
Colombia
Yes.... Wierd but could happen
Reactions: Kevkyo67
mano
New York
"Could the text message have caused the wifi to disconnect from the controller? "
I think so...I was told to always put phone on airplane mode and Bluetooth turned off....and also if you have a Bluetooth watch, remove it as they can case problems.
CenlaUAS
Thank you. Forgot about airplane mode. I was wearing my fit bit when I flew. I will keep this in mind next time I fly.
CenlaUAS
Follow up question:
How can I get the Sparks Blackbox files read? Noticed a folder labeled “Fatal” with contents in I believe Chinese in it.
Thank you again for any assistance.
zach31294
