minimum flying height
mnach
Is there a way we can set a minimum flying height? I recently saw a friend flying a Bebop 2, it has a "ground clearance" that can be set, he was flying over water not worrying about accidentally hitting the water, the sensor will prevent the aircraft from getting too low. On a lake, one can shoot activities without worry. Even if intentionally tried to lower it, it would stop at the set distance from the surface.
Nope.
It'd be a great feature for the Spark to include like all other DJI drones! I've nearly ran my drone straight into water several times getting those fast close to ground shots forgetting each time that the drone loses a bit of altitude when racing forward in sport mode...
There is a fix distance of 30cm (1 ft) with the vertical proximity sensor, but it is fixed and looks am not sure if it really works well when flying.
LucioHanle
