Motor problem warning!
chousehold4
Yesterday I was flying at about 300 feet when I saw on my iOS a warning that I had a motor problem! I immediately returned to home and discovered that a propeller was in contact with a wing guard chipping the end of the prop off . I removed the guard and every thing is fine however why does this warning not appear when I re play the flight video ?
It won't be on the Spark SD card.
There may be a logging of it in the flight logs that you'll have to extract from the device.
If you run a screen recorder on your device during the flight, that footage should be in the camera roll.
I occasionally run the recorder on my mini 4 so that I can watch the flight telemetry and any changes I may have done to the camera / video settings.
Sometimes the CPU of the mini may get a little overwhelmed and I'll get a warning on the DJI Go4 during the flight.
Thanks for the response ! The message stayed up for about 5 seconds I was fortunate to see it ! Otherwise it might have went down! New Prop! New Drone!
Was it a motor overload warning? It also happens occasionally when you are flying in Sports mode and you have both left and right stick pressed fully. Wind may also be a factor.
Not motor overload warning ! I knew by the sound when landing that something was wrong and I found the wing guard to be damaged and the prop tip chopped up ! The wing guard must have somehow moved.
vdbnoe
