Since you already exceed 30m, then it directly going to home point.I was flying normally (Height: 80 meters)
Then I lost connection and RTH was triggered. Then, the spark didnt go up 30m, as programmed, and it flew straight. Almost hit a tree. Why didnt it go up?
It's not true actually.Since you already exceed 30m, then it directly going to home point.
30 m is minimum height that user can set, but if it already exceed, then spark will not ascend anymore.
If it was true, then rth altitude setting would be useless.
You mentioned altitude, but you didn't mention distance.I was flying normally (Height: 80 meters)
i’ll definitely need help. I can give to you the flight logs. Can you help me please?You mentioned altitude, but you didn't mention distance.
Also, you didn't mention rth settings in go4 app.
Rth procedure is a little complicated, and is dependent on settings, distance and height.
I'll try. I am not a specialist, but you can upload your logs, and someone expert will check.****, i’ll definitely need help. I can give to you the flight logs. Can you help me please?
try setting it a higher setting . if i am reading what you said and if you are flying at 80m and you set at 30m that is 50m lower than what you set it at .it will not go up another 30m that's not how it works . it's from when you take off ground zero .I was flying normally (Height: 80 meters)
