My Spark's Live Video Feed Keeps Cutting Out Mid-Flight
max
Hey,
Just got my Spark and so far so good except for the fact that my Live Video Feed (on the DJI GO4 app) seems to cut out after about 100m... Is this normal? How can I try fix this?
Also, on a completely separate note: is there any obvious reason that everyone else's video footage seems to be much better quality than mine? Mine so far has had visible stutters in it and it looks kind of grainy in some bits....
Cheers,
Max
Hi, welcome
I assume you have the RC (Remote Controller).
1) No and Yes. No, it can do more for sure. Yes if you are in an urban area with a lot of wifi/bluetooth around you. One basic think is to disable Bluetooth in the device around you or leave them away.
2) The good quality video is on the uSD card, on your phone you have only a cached version transmitted by radio (video is 720p, not 1080p). Either you take it out and import the videos/pictures to your computer/phone or you use the GO4 app when connected to Spark and use the playback button.
Then you can browse the media in the Spark.
Select one.
Special photos like Panorama, AEB, Shallow focus can be then edited to create one resulting picture.
The file can be downloaded (slow process).
Reactions: max
Hi, welcome
Select one.
HI so:
1) I am using RC and I am NOT in an urban areas... I'm in a pretty empty rural area...
2) I am using footage from SD card..
1) Not that normal in your condition. Did you have some Bluetooth or wifi devices around you?
2) Did you tried to reformat the card in a PC and in the Spark?
1) Not sure... I tried again today and it seemed to go further... I guess I'll keep trying
2) Yeah I reformatted after posting this and I think it solved the issue!
LuxVitae
