OTG cable set up
I do as follows:
1 Put my mobile/tablet into flight mode insert cable end into device.
2. Turn on Spark
3 Turn on RC
4. When RC and Spark connected (green light on) plug OTG into RC
5. Run DJI Go if it does not start automatically.
It is important that you do not connect the OTG to the RC until RC Spark connected. Also make sure the OTG cable is plugged into RC not device!
Reactions: defishinsea
I do as follows:
2. Turn on Spark
3 Turn on RC
Hello Charlie,
Is this as safe as flying with WiFi, what happens if there will be something wrong with the cable?
I do as follows:
2. Turn on Spark
3 Turn on RC
At the end of your post you said make sure otg is plugged into rc not device. When at the begining you said insert cable into device. Confused.
KguaooNex
