Is it still supported on Spark? I've heard some firmware updates removed OTG support.Always OTG. Several advantages and no downside
It's simple to use and only costs $8. Not much to debate.
DJI made it standard on the Mavic for a reason!
That was ages ago. Latest firmwares fully support OTG.Is it still supported on Spark? I've heard some firmware updates removed OTG support.
That's good to know!In the past support for Android was flakey with each firmware update. You are probably still hearing about that issue which has since been solved.
It's been rock steady on iOS for about a year now.
Mavics don't use otg cable.Always OTG. Several advantages and no downside
And there is a downside. Otg cables sold are not all reliable.
There are lots of posts about otg cable problems.
Many users report cable problems here and in other sitesThe only "reliability" problems I have with mine are making sure I connect things in the right order. It either works or doesn't work, there's no in-between, and cables have never stopped working for me mid-flight.
For those using iOS devices, it is impossible to connect it the wrong way.
Sorry for my poor English, but I didn't understand your problem.Well, with my OTG cable, it has to connect to the controller BEFORE the phone. It would be easier to connect the controller last, as I could plug in and fully dock my iphone5 and then reach under and plug in the controller, but that's not recognized. I have to plug in the phone last and then snug it back into the bottom of the controller.
