pano function
Jeplane
Dallas, TX
When I clicked on pano in the DJI go app, it says that the photos will be stitched together automatically.
Yet, when I loaded them into Lightroom, they were separate, and I had to merge them myself.
Did I miss something?
Thanks
If you download the pano via the app, it will stitch it. If you copy from the SD card directly, you get individual photos.
I see.
How do you download from the app? Where does it go?
Thanks
Hi, I had the same problem. You need to be in flight mode to access playback, when you hit playback it stitches automatically. Now after I take a pano pic or two, I wait until I land, then even if the battery is low hit playback before shutting down, or swapping batteries. It takes a minute or two, but doesn’t use much battery power.
And remember to stop recording once aircraft lands
i turned mine off first time and lost all my pano shots
Reactions: Brojon
