A simple test to see how good the MAS (Master Airscrew) props are to the ear.
Tested my Spark and Brother in laws Mavic Air with both of their respective OEM props, then the MAS props on each drone, then did a side by side Spark / Air comparo.
Really interesting results.
The Spark definitely benefits from the MAS prop upgrade, it's just about silent compared to the OEM props.
Tested by flying out 5m, up 2m, filmed using same iphone SE camera from same spot.
The Spark . . .
Spark vs Air . . .
For anyone interested, the Air test alone . . .
Here are some photos of the Spark OEM and MAS props side by side, as close as I could get them on the side profile . . .
The MAS are slightly longer, a couple of mm (or 1/16" or so).
A really obvious larger blade and increased pitch = lower revs to lift are needed.
I wonder about the torque placed on the motors, obviously there is a trade off of the motors working harder at lower revs to do the same job . . . but of course the motors are not revving as hard.
Long term, I'm not sure if motors might suffer ? Think it would be hard to ascertain.
A set = 4 blades from MAS, not sold in pairs like DJI.
(I bought 2 sets of red props.)
The BIGGEST first impression I got when opening the package was, they are fixed one piece blades.
Not folding, which is a pain for both cases I have.
What I will do now is make a custom hard case setup for my Spark kit, as I recently bought some other goodies, and would like them all in one place.
Or maybe I'll set up 2 soft cases and take basic flight kit (with Spark fitted MAS props securely) in one for easy flight access, spare stuff in 2nd soft case, place both into a suitable backpack with easy access.
Anyway, I'd recommend these MAS props for sure, should make flying in some places a lot more comfortable, as I can be less concerned about people within earshot of the Spark while flying.
The Spark . . .
Spark vs Air . . .
