Propeller check FYI
pstik
Jeannette, pa
I just did an IMU cal. My propellers looked good and sturdy. Then I removed them and 2 of the 4 propellers had broken clips that hold them on to the spark. This would have been bad if they had failed during flight. I check props for stress damage but I never remove them. So I guess I will make this a check from now on.
Tentoes
Oklahoma USA
I found one that way too, though it had a chip in it. Better look close at the others.
twickers14
Will go and check mine. On the original set still! Spares still in the box. Thanks.
RotorWash
Prince Edward Island, Canada
Nice catch pstik, probably saved you some heartache. I know it sounds tightly wound but I actually pull mine off once every couple of weeks and check the entire prop with a magnifying glass under a good light. 🧐 Just don't want to be over water and have one crap out on me from not checking. 😞
Reactions: pstik and Rwarrior
Troy.Spark
I use to check mine as well once a month by removing them and putting a little pressure on the tabs I found that the get hairline cracks that you can’t see until you put just a little pressure. I found this buy removing them one of the tabs stay inside my motor and that was a pain to fish out.
Tentoes
Oklahoma USA
Perhaps we've stumbled on some periodic maintenance requirement.
Reactions: pstik
Ray215
