Remote and Spark charger Micro-usb cable
Simk1n
My Spark came with a White USB to Micro usb (rectangle) cable that goes into the power brick to charge the Remote Controller or into the back of the Spark.
To my understanding this is a Micro Type-A cable? but i cant find this cable, or a Micro Type-AB cable. I also read that a regular Micro Type-B will fit but charge it much slower?
In the original store i cant find it either.
That supplied cable or any equivalent will charge the Spark remote from the brick just the same. It will not charge the
Spark from the brick. You must use a dedicated charger eg. the 3 bay tray to charge the Spark battery. You can use the cable to access the SD card in the Spark from your computer(Spark switched on).
vdbnoe
