Setting the time on the DJI Spark?
Andrew7
I wonder if others have run into this problem and found a solution. The timestamp on my recorded videos is off by around 8 hours or so. Is there a place I can set the time on the drone so it stamps the files with the right time?
Have you checked the time on whatever device you are using with the GO4 app?
I have, yeah. Everything looks in order there.
Well, then I'm stumped because there is no time setting on the aircraft. Not sure if the system gets its time hack from the GPS signal or from the device.
Just a wild guess:
Maybe the Spark files are time stamped in Greenwich Mean Time and you are 8 time zones west?
ratski24
