Skin wont work with prop guards
Roy Adams
I got a skin cover from Decal Girl, and covered the Spark.
The skin was well done, and looks great, however would not allow use of the propeller guards. The extra thickness around the motor mounts made the diameter too large to accept the guard. After removing the motor mount wrap, I found that the arm wrap would not allow the clamp to close, so I had to remove the arm wrap.
So, I am still pleased with the partially covered Spark and Controller, but thought I'd mention this minor problem.
Roy
Good to know! Thanks for the heads-up.
Also have decalgirl wrap and And found following:two other things will be tight: adding the box landing gear and some tight foam in some pelican type cases.
vdbnoe
