Spark DJI Charging Station power pack - just purchased one from D1 store in Perth - Anyone had experience?
Experienced users, has it been a good device ? What has been the pros and cons ?
I have it for about 4 months ..charging slower than the 3 way charger that came with the combo but really useful for me ..I splashed out and bought the case for it so its protected to take on hikes and biking
I have it for about a month now. Charging may be slow, but it charges on the go! (Have it together with the dedicated bag).
Some people have complained that it doesn't fixate the props, but it does; when you close the clamp, rotate the props to the outside, and they will be kept in position by the recession in the clamp.
One issue is that I wanted to charge my phone as well on the go (as flying the mavic and taking tons of pictures during a hike really drains the phone's batteries), but then the USB connector of the charging station is blocked by the carrying case. When you rotate the charging station over 180degrees, there is space to keep a USB charging cable plugged in whilst the charging station is in the bag.
A big advantage over the original foam box is that the carrying bag also holds the controller (but not the charging brick).
Reactions: Ozboyblu
Like it but i don't love it. I usually pop the batteries in right after they come off the Spark, and i will need to remember in 30 min re pop the battery off and put it back on or else they don't charge due to the temp
Good to know..I wasn't aware of that either. Now when I pop the batteries in immediately after coming out of the spark, I start to see the green light representing the battery start to flash. Is it your feeling that even though the light is flashing the battery is actually not charging
Al
Pilot6521
