Spark help needed
regardtnaude
Hi, I need some help with my Spark. I bought it from a friend that paired it with his remote but sold it without it and battery.
Now all that it does is flash yellow quickly and pressing the battery button does 0 for reset. Also usb does not show when connecting to pc.
Any ideas maybe plz?
Tx
Skip to about the 2:30 mark of the video and Ty will explain how to bind / unbind with a remote or the phone.
Good luck. :)
Reactions: Deanph
there is also a driversetup.bat into the assistant2 install directory under driversC:\Program Files (x86)\DJI Product\DJI Assistant 2\Drivers , and you can check the driver is install correctly, into you windows hardware, if not delete it and reconnect spark via usb, it should install driver again.
