(No longer for sale) Spark with three batteries and charging station - dropping price to $250.
joeke3el
Dropped to $250. Not using this drone anymore and would really like to see someone use this.
Flying new drones now and it's time to put my Spark up for sale. It'll be missed but if I keep it, it probably won't get used much. This setup includes the charging station which can charge all three batteries once so out in the field it's like having six batteries with you. It also doubles has a sturdy carrying case. $400 and can only sell to the lower 48 states. The Spark has never been crashed and has been reset to factory settings via DJI Assistant.
Included:
Spark
Controller
3 batteries
Spark Charging Station (charge on the go!)
ARGtek range extender antenna system (see video below breaking 10,000ft)
- 2.4GHz/5.8GHz vertical and panel antennas
- 2.4GHz panel antennas
Oringal antennas included, can be reinstalled
Extra pair of 6dBi WiFi antennas for more compact travel
Original Styrofoam case
wall charger and two battery charging cables
two extra props (one prop has slight crack from hitting grass, you may want to discard)
OTG cable
Times charged on batteries
1. 52 times
2. 59 times
3. 44 times
See this Spark in action:
Range test with included antenna system:
Spark flying over the old Bethlehem Steel factory:
You may have already posted this, but what have you purchased as a replacement?
KguaooNex
