TIPS FOR FLYING YOUR DRONE IN WINTER
elfatih
With Winter quickly approaching, Heliguy Insider have been looking into tips for flying your drone in the colder months.
Here in the UK, you might not think there’s much you need to do differently, but with cold temperatures and a greater chance of rain and snow, you need to make sure you’re taking care of your drone and flying appropriately.
Colder temperatures can affect the aircraft and its batteries, significantly reducing flight time if you’re not careful.
Keep reading for our tips on flying in the winter months to help you avoid any issues.
Dress Appropriately
First things first, you need to ensure what you’re wearing is right for flying.
Make sure you wear plenty of layers and a coat to keep yourself warm. You don’t want to get your drone up in the air to realise you’re freezing and have to bring it back down again to put a coat on.
The most beneficial item of clothing for drone pilots in winter is gloves. Your hands will be out in the open for the entire time you’re flying so make sure you have a pair of gloves on that won’t interfere with your flying ability.
We recommend using a pair of touchscreen gloves, so you can still access your device during flight.
Preparation and Transport
Preparation is key every time you fly your drone but particularly important when flying in winter.
Firstly, plan your flight location before you travel in the cold with your drone. Make an image or video shot list and know what you need before take-off. Avoid flying in difficult locations such as over water as you may need to land your aircraft at short notice if the temperature drops or it starts raining.
Charge your batteries to 100% before use. It’s recommended that you don’t fly with old batteries that may be unreliable as colder weather may put stress on them. For some aircraft, battery insulation stickers are available to offer additional protection from the cold.
As well as keeping your batteries fully charged, make sure you charge your smart device before flight. It may also be affected by cold weather so make sure you monitor it.
Pack the aircraft and batteries in an insulated case when possible to keep the heat in. During transport, keep the equipment in the warmest place available. If you’re in a car, keep it on the back seat rather than in the boot.
When you arrive at your flight location, keep the batteries in pockets close to your body rather than in a cold case. Models like the Inspire 1 have battery heaters, so use these if required. The Inspire 2 and Matrice 200 series have self-heating function for their batteries for added reliability.
Keep the weight of your aircraft to a minimum by avoiding any additions you don’t need. This will help give you the maximum out of the aircraft’s batteries in the cold weather.
Before your flight, make sure you complete a thorough pre-flight checklist. Carefully check your propellers for any damage as the colder weather will put extra pressure on them. If there’s even minor damage, don’t use them.
If you’re prepared for your flight, it will help you avoid difficult situations and unnecessary pressure that adverse weather may cause.
Keep reading for more tips on winter flying to help keep your aircraft safe.
Avoid Moisture
One of the biggest issues you will face in winter is your aircraft coming into contact with moisture.
First off, use a launchpad for taking off and landing your aircraft. This will help keep your drone dry and avoid mud and dirt.
Unless you have an aircraft like the DJI M200 series with IP43 weatherproofing, don’t fly in rain or snow. We understand, flying in snow can create some amazing shots and footage but you are putting your aircraft at risk.
If it starts raining or snowing when you’re out flying, you can fly your aircraft backwards can help protect your camera. However, this should only be done if you can do so competently. Try practising when you’re not under pressure to protect your camera.
Remember, clouds also contain moisture so avoid flying into them.
Once you land your drone, check it over for any moisture including the batteries and camera. Wipe down the aircraft with a towel and ensure it’s completely dry before you pack it away.
Drone Flight
During your flight, the main areas you will need to pay attention to are the battery temperature and voltage.
When using the DJI GO 4 app, you can check these under the battery settings. Make sure you stay in the recommended battery temperature range found in your aircraft’s user manual. For the battery voltage, this will show in green, amber or red. If the battery voltage colour goes red or drops below 3.2, land the aircraft immediately.
As soon as you take off the aircraft, hover for around 60 seconds at a maximum of 10 feet. Monitor the behaviour of the aircraft, the battery and the app to ensure their performance is normal.
During your flight, try to fly your aircraft with smooth and gentle movements. This will help conserve the battery and not waste your power. It’s also worth noting, colder temperatures result in the air being denser. This means your aircraft will be more responsive, especially if you’re flying below 0°C. Be careful when flying in these conditions if you’re not used to it.
As well as watching out for precipitation, high winds can be more common in the winter months. Check the wind speed before your flight to ensure your aircraft is suitable to fly. When winds are high, fly with caution, especially if you’re not used to these conditions.
Additionally, you should pay attention to all warning messages on your app. Follow any advice given to you by the app and land if you’re prompted to do so.
Finally, limit your flight time compared to your usual flight. Don’t run your battery down until it’s empty. Land the aircraft and check it as we discussed above to ensure there are no issues.
Propeller Icing
Especially in the UK, you may think that icing won’t happen but, in colder temperatures, there is a possibility. It doesn’t have to be below 0°C to happen either.
Icing is where there’s a build-up of ice on the propellers during flight which can result in prop damage and in extreme cases, a drone crash.
Icing occurs due to a combination of cold temperatures and moisture in the air. Flying in clouds or mist, combined with temperatures below 5°C may cause a build-up of ice. It can occur above 0°C due to the high speed of the propeller reducing the temperature.
As we have discussed, monitor your drone during flight and if you suspect icing is occurring, land immediately and dry your aircraft.
thank you
that's very kind of you
Every time you copy-paste an article from another site, it's fair to mention the link to it.
Karolisius
