Use LItchi mission with one waypoint only
Raoul
Italy
I need to have the drone always locked in the same position, but on different days. Can I use Litchi with a single waypoint to do this? Obviously the "Finish action" parameter will be set to None. Thank you.
Well, I just tried. Litchi does not allow you to save a mission with a single waypoint, but adding another one fairly close to the first one solves the problem. Once the second waypoint is reached, the mission ends and the Spark hoovering on the last position reached. I hope that tomorrow will be the same position ;););)
That is what I was going to suggest.
Make the point where you need it.
Make another point close to home.
Go back and use the action command at WP 1 "Stay For" xxx.seconds.
vdbnoe
