VPS and baro/gps height confused?
gdanas87
Hello guys, can anyone tell me why on the height osd display i keep seeing vps info (incorrect readings of 2.5m on actual 80m height) going back and forth from the actual barometer/gps calculated height?
It doesn't affect performance much when the craft is high up, but I don't trust flying this way. When I am down low I might get very small height hold flunctuations but nothing alarming. The bottom sensors are completely clean and undamaged.
Could be :
-since you are over water (i have read that can cause issues sometimes)
-dirty sensor
-sensor going bad (had you had any crashes) or defective sensor
I am sure others will chime in just wanted to help get you started.
Reactions: gdanas87
Hi, after try the "gesture piloting" in dji go 4 i have the same problem : strange height, no front off obstacle and no landing "bip". All seem to be desactivated .
I try to change firmware, reset factory, uninstall dji go... no effect :(((
Could you help me plz ?
vdbnoe
