*WANTED* Dji go4 - mod-45-spark-4.1.15-november-from-i.apk for Super Patcher
JeyTea
Hello Folks,
does someone possibly have the above app version and could share it? Many Thanks
Hi Giuseppe,
thank you. Is this the Version which is designed for the super Patcher Mod? There were 2 Versions, one of them was espescially designed to be used with the Super Patcher Mod and had the Notifications for NFZ disabled..this is the one i am looking for. Could you confirm that this is the one?
Thanks again
I need the file which is named
>>>>> "mod-45 Spark 4.1.15 november from I for super patcher.apk" <<<<<
you can see at the following linked Post that there are 2 Versions..
Do you also have this version to share?
Thanks
Reactions: natasha7888
Here is also a Screenshot of the Post where you can clearly see that there are 2 different Versions of this App.
Does anyone else have this specific Version to share?IMG_20201011_120257.jpeg
seems to be a killer app, all seem to be dead who downloaded this app :) no one answers, no one moves ...
Pushing up, hoping someone can help Out..
Looking for the November Version designed for Super Patcher
what does this app do? should I download and install it on my spark controller?
Short answer NO, unless you want to run the modified Go4 app that unlocked some of the Mavic abilities to be used by the Spark.
Here is where it all started in 2018.
I haven't installed it myself but for those that have it seem to like it.
This app give you a lot of features, important one is for people living in Europe, you get permanent FCC power.
Also you got offline maps, no need to use internet anymore, you are anoumenous, no active connection to the dji server.
It block Firmware upgrade., you get extra flightmodes like the Mavic Pro, include waypoints.
It is build from the most stable version 4.1.15 and you can use the OTG cable.
An other version is when using the superpatcher firmware, that version contains all above but also no more NFZ/hazards warnings.
Superpatcher firmware delete NFZ and height limits on your Spark, also make the galileo sattelite's active and the option to use Boost Power(1.5 watt) for Spark and RC which overrule the FCC power(0/4 watt).
Thanks😍:)
Yes, I've saved it. I enjoy it.
KguaooNex
