Depending on what you want to do with waypoints, I have not had success finding an app that will do mapping. I believe autopilot might do points of interest based on waypoints but not mapping. I can not confirm that. I can confirm that Drone Deploy and Litchi will not fly waypoint missions with Spark. I hope someone else has bettter news.I bought a spark and trying to figure out how I can plot a course using the waypoints can someone help
Yes, you can save the route until you save another one, then it is gone........ Some one might find that usefull I supose??With the modded app on this forum you can do waypoints "mavic-style". You cannot pre-plan, but have to fly the route, saving each waypoint. Route including waypoints can then be saved.
Pix4d is 150 USD per month to use. At that point I stopped trying to figure out if it works with Spark, or any other drone for that matter.What about Pix4Dcapture? Not sure if the Spark is compatible, but might be worth the research.
I believe Capture is a free flight planning app, but yes the Mapper and other applications do have a price. Didn't know if you could use it for way point flights or not. BTW it does not support the Spark, so disregard the suggestion.Pix4d is 150 USD per month to use. At that point I stopped trying to figure out if it works with Spark, or any other drone for that matter.
Hello from the Mid-West, Shane.
You'll have to research for a third party app like Litchi or Autopilot to work with the Spark on a waypoint mission.
The Spark itself can't do it.
Welcome to the Forum .
This is contrary to everything I've read thus far. Litchi does not support waypoints with the Spark because it uses the official DJI API as the framework (which also does not support waypoints for Spark). The reason Autopilot waypoints work with the Spark is because Hangar used their own proprietary API to build their app.Use litchie it's work to dji spark
That is not very comforting news! How far out were you on your mission? Was it possible it was too far and the drone lost connection? From what I have read the waypoint mission must be within signal range of the drone since the mission is stored on the iOS device. There is an option to enable LCMC but then not all options for the mission are available.I did use Autopilot to fly one simple mission, and at the completion, the drone stopped and would not respond to control.. I was using the remote.. was pretty sure I'd be picking pieces up off the ground when the batteries ran out, but I was eventually able to get the DJI app to connect and take control and land the drone...
I use Autopilot for waypoints and I love it. I REALLY like being able to create the waypoints in Google Earth Pro on the PC with a big ol' monitor and then export that to the iPhone 8 Plus that I fly from. It just feels roomier than creating a mission on the iPhone.I bought a spark and trying to figure out how I can plot a course using the waypoints can someone help
I wrote up a HOW-TO here
A few caveats:
1. - You can create the waypoints on Google Earth Pro, but not things like Subject Focus, meaning what the drone's camera will point at during the mission.
2. - It will not import altitude information from the waypoints you create in Google Earth Pro. You'll adjust the altitude for either the mission as a whole or the individual legs, inside of Autopilot after the import.
3. - When you import the mission into Autopilot, it has the mission layout backward, so what you've labeled waypoints 1 through 10, for example, will show up as 10 through 1. Very easy fix, pointed out by user 'scoobi' - "You can easily reverse waypoints order, tap on the Waypoint Reference icon once (orange teardrop icon with three other teardrops in the middle of it). Then tap on the bubble "Tap for options.” A pop-up will appear: select "Reverse Waypoints.” Et voilà!"
I will not tell you that Autopilot is easy or intuitive. But the time you spend in its Flight School learning how to take advantage of what it can do will open up a whole new world of cinematic possibilities.
