Hi
It is looks too heavy and create too much turbulences from the floating elements, just my opinion.
If the prop guards can be removed or cut, it could help for weight.
You can also try to remove the vertical tube of foam, they don't bring flotation but add weight and drag close bellow the propellers.
Now of coarse it depend on your need of that system for your use of the Spark.
You and I are thinking the same but you must type faster as it takes a minute for me to express a thought.![]()
Well the green rubber band is just a security to hold battery safe in place.
Did anybody have a problem with battery fall out during flight? In my opinion battery holds fine there.I've seen a picture here on the Forum posted by somebody else that is similar to the example here but using a large rubber O ring available at an auto store and strapped on this way.
The battery has to slide back a little before it falls off downwards.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
