What is this huge green circle on the map?
Achilles75
There's a huge green circle on my map. By way of comparison, you can see two airports on the map as well, but this green circle takes up about 1/2 of the state of Virginia. What is this?
Class D or E (?) Airspace warning zone. There is a gear icon on the map toolbar (top right), you can select what you want to display as warning space setting.
I have same one and it is a Class D, maybe yours is Class E.
It's definitely not a Class D or E - I've toggled both of those (and all the other options) off and on. This is considerably larger, many times larger, than any of the Class E airspaces.
More than likely an AIAA (Area of Intense Aerial Activity) - common on air chart sectionals
JeroldLabe
