Good morning, I just realize, there are no nfz zone with this app? Or my phone not loading map correctly? Still cannot fly on nfz though
Hello. I use DJI GO 4.1.15 mod on a Xiaomi 11 lite 5G (see picture).
It works but don't ask me to switch FCC.
I've used FakeGPS with USA location but I've always 13ch wifi.
Why? What's wrong?
What are the steps to switch in FCC?
Thanks a lot.
Why? What's wrong?
Thanks a lot.
So, before you open DJI GO mod, you have to turn off data first, because android 11 up data always on
Hi! I tried to delete the folder and then uninstalled the original app but when trying to install the new one my phone asks if I want to update the app. If I click yes there's an error (as seen on the screenshots). Its in german but says something like "the package seams to be invalid".
Hi guys , installed modded go4 app to my phone the other day after I had uninstalled the original app, then realised I had an old phone I could use it on and keep the original app on my good phone , My problem is : after several fresh installs of the original app it still asks me do I want to opened the go4 app when I connect my inspire 1 (which I don't have ) and then tells me I'm flying in a different country , which I'm not , my range has increased from 747metres to around 3.7km , has anyone else had this issue and is it safe to fly still I'm not looking for range but the video transmission is way better
Trying Mod 2.0 on my Pixel 4 XL results in the phone rebooting when any options are chosen
It's on Android 12
OTG gives a visual, wifi doesn't - but changing any settings while connected results in the phone just hard crashing and rebooting on the spot.
Any known fixes or workarounds i can try?
DJI GO 4 MOD 2.0
  • Auto enable screen rotation
  • Red Status and Nav Bars
DJI GO 4 MOD LITE
  • Offline Maps
  • Here Maps
Both Apps Feature:
  • OTG Support
  • Sphere Pano Support
  • DJI GO 4 Ver. 4.1.15
Downloads
DJI GO 4 MOD 2.0 - Download
DJI GO 4 MOD LITE - Download
Changelog
DJI GO 4 MOD 2.0
  • New Custom Icon
DJI GO 4 MOD LITE
  • Initial Release
DJI GO 4 MOD 1.1.1
DJI GO 4 MOD 1.1
  • Fixed Google Maps
  • Keep Screen On Added
  • Added Auto 100% Brightness
  • Added Auto-Rotate
DJI GO 4 Mod 1.0
  • Initial Release
Tested Devices
  • Nexus 6P - Android 8.1
  • Nexus 6 - Android 8.1
  • Mate 9 - Android 8.0
  • HTC U11 - Android 7.1.1
  • Samsung S7 - Android 7.0
  • Sony Z3 - Android 6.0
Credits
PayPal: [email protected]
DJI GO 4 MOD 2.0
DJI GO 4 MOD LITE
  • Offline Maps
  • Here Maps
Both Apps Feature:
  • OTG Support
Downloads
Changelog
DJI GO 4 MOD 2.0
  • New Custom Icon
DJI GO 4 MOD LITE
  • Initial Release
DJI GO 4 MOD 1.1.1
DJI GO 4 MOD 1.1
  • Fixed Google Maps
  • Added Auto-Rotate
DJI GO 4 Mod 1.0
  • Initial Release
Tested Devices
Credits
id like this ap to work on my Samsung a70. i used it on my Huawei g8 and worked like a dream. please let this app work on my samsung
Any chance to reup the Lite version? Thx
ariadef
