FrSky Xact Series Micro HV 8.4V Capable Servos HV5201/5202/5203
FrSkyfans
FrSky Xact series coreless servos utilize all CNC machined aluminum protective case and metal gears, these servos are 8.4V high voltage capable and offer high speed and configurable torque performance. Also, the Xact series servos offer multiple form factors and configurations to fit for different model types and precision usage.
Working with the F.Port 2.0 protocol, the telemetry data (like real-time current and voltage) of Xact servos can be achieved and transmitted back to the radio by connecting either F.Port 2.0 capable receiver or flight controller. All the preset servo options of speed and torque can be configured directly on an ACCESS radio through the host device of F.Port 2.0 line, and the configurable servo steering as well as travel degree are additions now can be expected on this series.
FEATURES
Supports F.Port 2.0 SBUS and PWM protocol
High durability with metal gear and all-aluminum CNC machined protective case
8.4V high voltage capable operation with good speed performance
Built-in dual precision balls bearing with hall sensor
Supports over-current and over-hot monitor and alarm
Updatable firmware ensures the performance superior
SPECIFICATIONS
HV5201
Torque @ 6.0v – 3.0 kgf.cm / 41.7 Oz-in
Torque @ 7.0v – 3.5 kgf.cm / 48.6 Oz-in
Torque @ 8.4v – 4.2 kgf.cm / 58.3 Oz-in
Speed @ 6.0v – 0.06 sec/60°
Speed @ 7.0v – 0.05 sec/60°
Speed @ 8.4v – 0.04 sec/60°
Dimensions: 23*12*29mm (L*W*H)
Weight: 23g
Motor Type: Coreless
Servo Horn Spline: Φ5 25T
Stall Current: [email protected] / [email protected] / [email protected]
Operating Voltage Range: 4.8-8.4V
Max Refresh Rate: 333Hz
HV5202
Torque @ 6.0v – 3.5 kgf.cm / 48.6 Oz-in
Torque @ 7.0v – 4.0 kgf.cm / 55.5 Oz-in
Torque @ 8.4v – 4.8 kgf.cm / 66.7 Oz-in
Speed @ 6.0v – 0.08 sec/60°
Speed @ 7.0v – 0.07 sec/60°
Speed @ 8.4v – 0.06 sec/60°
Weight: 23g
HV5203
Torque @ 6.0v – 5.9 kgf.cm / 81.9 Oz-in
Torque @ 7.0v – 6.8 kgf.cm / 94.4 Oz-in
Torque @ 8.4v – 8.2 kgf.cm / 113.9 Oz-in
Speed @ 6.0v – 0.11 sec/60°
Speed @ 7.0v – 0.09 sec/60°
Speed @ 8.4v – 0.08 sec/60°
Weight: 23g
Stall Current: [email protected] / [email protected] /[email protected]
Delf
