Litchi Warning Battery Power Limit
cowznofsky
I have a Spark and am running Litchi on my Pixel 3 with Andoid 12 (because the DJI Go app keeps crashing). I tried to fly today, but after getting a GPS signal and trying to take off, I get a message on the screen saying 'Warning. Battery power limit. Low drone mobility' , and the propellors would not go.
The drone and the controller were each over 60% battery, and my phone was charged as well.
Any idea what is going on?
Never start a drone flight if battery isn't 100% charged. The first minutes there's a high current drain due to heat up the battery . So the voltage drops for about half a minute to a level on which the drone thinks the battery is going to be empty very soon .
In summertime this mostly happens after some minutes flight . The drone sets in safety landing immediately . But if you keep up pushing left stick up the drone will remain in the air and after a minute the battery is warmed up and current drain is be normal again. Scary indeed. I think if battery is cold it will refuse to start .
This occurs too with my MP1.
Reactions: giolodovico
Could it be a cold battery and Litchi not telling you this.
Log in in airdata Uav and you het a complete datalog of your battery
ayitsomar
