S/N Erased on the Battery Compartment
I recently got a DJI Spark and the Serial Number of the drone is erased towards the end. I was wondering is there any other way to get it because In the Dji Go4 app it only shows the controller S/N.
Thanks I'm advance
The serial number is stored in the TXT flight logs. You can view the contents of those TXT flight logs here.
Can you post a link to one of the TXT flight logs you uploaded?
Alright, I'm just giving you a few incase some don't have what you need. Thanks as well.
  • DJIFlightRecord_2022-07-24_[16-53-41].txt
  • DJIFlightRecord_2022-08-29_[11-57-39].txt
  • DJIFlightRecord_2022-08-05_[11-13-55].txt
  • DJIFlightRecord_2022-08-03_[12-24-33].txt
03Z0619644
Can you post a photo so we can see what you're describing?
3 of those 4 flight logs are from a P3S named "Royal Skies". That's aircraft serial number 03Z0619644.
The 4th flight log is from a Spark with aircraft serial number 0BMUF9C00100HX. Was your Spark refurbished/repaired at some point?
Oh I didn't even know which one
They all had yesterday's date which I took out the Spark and P3s was home
I actually bought the Spark on Friday o don't know if it's refurbished or not but it was in good condition I'm sure he bought it refurbished as well but I wouldn't mind much anyways.
Thanks a lot @msinger
Delf
